mould appearing on skirting 2 weeks after damp proofing done
slimworld
by slimworld » Tue May 26, 2009 1:58 am
Would anyone be able to explain the above to me.
3 weeks ago a damp course was done into a property that i recently renovated and new plaster and skirting was replaced, Today upon inspection of the property the skirting boards all the way around the ground level floors was covered in mould spores.
Is this normal?
bd3cc
by bd3cc » Tue May 26, 2009 9:32 pm
Don't know if this is normal, or not, but presumably this work was carried out by a company offering a 30yr guarantee.
If so, contact them.
LCL
by LCL » Mon Jun 08, 2009 10:11 pm
slimworld
There is a very very good chance that you did not need a retrofit DPC.
Dampness affecting the internal parts of a house can be due to lots and lots of reasons such as high ground levels, overflowing / poor gutters / rainwater pipes, leaking services, old main supply, condensation etc.
In my many years as a Chartered Building Surveyor I have never had the need to recommend a chemical DPC (which I assume you have had installed).
If, for arguements sake the damp was due to say a defective lead watermain that has been saturating the wall, a DPC is installed and the internal parts re-plastered. The leaking water main will still be there and will still be saturating the floor joists and wall and the 'special' plaster will only be taken down to floor level. The guarantee will be only for the DPC injection and will not cover other forms of contributing damp,so you may findthe company will conveniently wiggle out of blame.
I hope this is of some use, even if I have assumed a lot.
regards
LCL
It is currently Wed Jan 15, 2025 9:24 am
