To stop a pipe without closing the main
bjn
by bjn » Tue May 26, 2009 7:00 am
Hello,
Without closing the main is there any valves or water stopper I can install on a 15mm pipe to stop water in this pipe.
thank you
bd3cc
by bd3cc » Tue May 26, 2009 10:30 pm
You could try freezing the pipe,(freezer kit available), cutting and usu push fit stop end,or isolating valve. You will have about 20mins to complete the operation.
Why cant you not shut the water off?
ps have replied to you previous request.
HTH
bd3cc
by htg engineer » Wed May 27, 2009 7:41 pm
Do you want to work on the pipe without turning the mains cold water off ?
or
Do you want to turn off the mains cold water and install a valve so that in future you do not have to turn mains cold water off ?
htg
bjn
by bjn » Wed May 27, 2009 9:01 pm
Thank you for your help,
I want to work on the pipe without turning the mains cold water off ?
plumer has been in to relocat a new builer and left the origenal water pip sticking out of the ground with a push stop on it . I must cut this pip down enough to go under ground so I can put carpet.
bjn
It is currently Sat Dec 28, 2024 8:07 pm
