copper clout nails for clay tiles?
mortarboard
by mortarboard » Fri May 29, 2009 7:35 pm
I am matching my old roof on a small extension and have 500 reclaimed clay tiles. I am planning on using 3.35 x 30mm copper clout nails to fix them to the battens. Could anyone tell me if I am using the correct nails and also how many of the tiles should be nailed?
Many thanks
by stoneyboy » Sun May 31, 2009 10:24 pm
mortarboard,
If they are clay peg tiles you will have to use clay tile pegs (which are like giant nails) which hook over the top of the batten.
If they are all nibbed tiles you should nail the bottom three rows every 4 row and the top 3 rows.
You may find the battens are too hard for copper nails and you will have to use galvanised clouts.
mortarboard
by mortarboard » Mon Jun 01, 2009 9:08 pm
Thanks for that stoneyboy
The tiles are nibbed. Someone else suggested the galvanised clouts might be more practical. When you nail a tile should you use two nails for each tile or is one the standard?
It is currently Sat Nov 16, 2024 6:15 pm
