Kitchen wall units - minimum gap to ceiling?
6 posts   •   Page 1 of 1
JonW
by JonW » Sun May 31, 2009 9:05 pm
Can anyone please tell me the minimum gap for standard kitchen wall cabinets from the ceiling?
I assume the answer may differ depending on brand of cabinets, but I'd appreciate any guidance/opinions.
I want to fit the cabinets as close as I reasonably can to the ceiling due to the gap between (slightly higher than usual) worktops and the wall units being quite restricted. I also intend to somehow fill whatever gap is left, flush with the actual cabinet body front edge.
Thanks in advance,
by stoneyboy » Mon Jun 01, 2009 10:08 pm
JonW,
Most ceilings are not level or even but you can fit the units as close as the mounting fittings will allow.
JonW
by JonW » Mon Jun 01, 2009 11:39 pm
Thanks for the reply, stoneyboy, I understand your point but, if the ceiling were level, how close do the mounting fittings allow?
by stoneyboy » Tue Jun 02, 2009 9:35 pm
JonW,
Depends on the quality of the fittings but you will be lucky to achieve a gap of less than 25mm
JonW
by JonW » Wed Jun 03, 2009 11:38 pm
Thanks, stoneyboy.
What brand(s) rank as good quality in your personal opinion please? Also, can you tell me where I can get them please?
by stoneyboy » Thu Jun 04, 2009 11:14 pm
JonW,
If you google "isaac lord" they keep some which I have found reasonable.
Don't be tempted by B&Q ones they are useless with very little adjustment.
It is currently Fri Jan 10, 2025 2:54 am
