newel post dowel joint?
george-doors
by george-doors » Mon Jun 01, 2009 5:17 pm
i have recentley moved into a house without a handrail so am looking to fit one. i have some limited carpentry skills but was wondering if anyone could explain how to fit a newel post to what is left of the old newel post safely. a dowel joint sounds easier than a tennon and i have seen newel posts that appear to already have a dowell or pin in the bottom?
cheers george.
by stoneyboy » Mon Jun 01, 2009 10:31 pm
george-doors,
I assume you have only the lower bit of the existing newel post remaining.
If this is so using a dowel will not strong enough - you will have to try and form a halving joint.
It is currently Fri Nov 15, 2024 7:38 pm
