preparation to paint an internal concrete wall
robag5
by robag5 » Tue Jun 02, 2009 10:46 am
having removed several layers of wallpaper from my new apartment, ive found the wall underneath is concrete. how should it be prepared for painting?
bd3cc
by bd3cc » Wed Jun 03, 2009 9:26 pm
Dont think it will be concrete. It is probably an sand/cement render, used internally, which is then plaster skimmed.
How did you remove the wallpaper?
I suspect that you have removed the smikcoat in your enthusiasm to remove the paper.
This would not be difficult if it was not keyed properly, and blown.
I would have the walls reskimmed to provise a good surface for painting.
It is currently Fri Nov 15, 2024 8:44 pm
