73mm bricks
matchdayblue
73mm bricks
by matchdayblue » Tue Jun 02, 2009 1:07 pm
What is the best way of tying in an external brick facing of a 250mm cavity wall when using 73mm facing brick. The internal skin is 215mm high concrete block so using a 73mm high brick with a 10mm bed joint obviously the coursings do not line through. There is also the problem in that the partial fill cavity slabs will line up with and are tied in with the blockwork coursing.?
Perry525
by Perry525 » Tue Jun 02, 2009 8:18 pm
Adjust the thickness of the motar to match.
matchdayblue
by matchdayblue » Wed Jun 03, 2009 2:17 pm
3no 73mm courses = 219mm without any mortar and 1no block = 215mm?
It is currently Fri Nov 15, 2024 8:52 pm
