fixing a tv bracket to the wall...
foley
by foley » Wed Jun 03, 2009 1:34 pm
when using coach screws do you need to use plugs on brick walls ???
bd3cc
by bd3cc » Wed Jun 03, 2009 11:07 pm
Would say yes, but would ask:
Is this internal?
Is it into brick?
Are the fixings required not supplied?
Tim Bernee
by Tim Bernee » Tue Feb 23, 2010 11:46 am
I am wondering if I where to fix just the 2 middle screws as seen in the pic to the stud framing and the other 4 outside screws to just the plasterboard will the TV weighing at 15kg and the bracket stay up? Or will I have to buy a long bracket so I fix all 4 screws to the stud?
chris_on_tour2002
by chris_on_tour2002 » Tue Feb 23, 2010 9:56 pm
six fixings carrying a total of 15kg will give two and a half kg per fixing. this should be fine, especially if two of those fixings are securely in studs.
It is currently Mon Dec 23, 2024 6:28 am
