roof construction detail
Kamel
by Kamel » Sun May 27, 2007 11:21 am
Assuming its the inner skin that supports the weight of the roof, do the base plate ends of roof trusses have to overlap the inner skin at all ? the base plates are sitting on 100mm of engineering brick. I can't find the relevant bit of the building regs ( uk ).
thank you
thedoctor
by thedoctor » Sun May 27, 2007 12:55 pm
The regs state that a minimumbearing is required at each end of the truss depending on the load and that load must be transferred alomh the wall by means of a wall plate. This wall plate is usually a 4 x 2 inch timber sitting on the top of a 100mm wall. The only reason trusses usually cross the caity and go through the outside wall is to take the roof surface beyond the external wall. If your trusses finish on an inside skin, what happens to the roof surface ?
Kamel
reply
by Kamel » Tue May 29, 2007 8:00 pm
Thank you for your explanation - it does fit with type of construction being put on. thank you
It is currently Fri Jan 03, 2025 1:43 am
