1 light 2 switches is this 2gang 1 way or 1 gang 2 way???
mrs kerry
by mrs kerry » Fri Jun 05, 2009 7:05 pm
I am trying to wire in a new switch cover but wondered which one to buy. I have central ceiling light with 2 switches. Is this a 2 way 1 gang and what wires go wire as it talks about switch live and live?. i have red yellow and blue wires. Please help!
kbrownie
by kbrownie » Sat Jun 06, 2009 3:09 pm
mrs kerry,
If you can operate the light from two different switches it is a two waw switch.
They should be wired as follows
On your switch plate terminals you should see identification at each terminal.
Com or L= Yellow
L1=Red
L2=Blue
sometimes the L1 and L2 need to be swapped to operate correctly, it may be a good idea to look inside your second switch and look to see if L1 is red and L2 is Blue there may be other cables in the second switch but
ignore them!
KB
It is currently Wed Dec 25, 2024 6:13 am
