My hot and cold feed into an existing installation are the wrong way round. I need to swap them around. They are coming into the room vertically.
My question is how large a hole will I have to chase out of the wall to be sure of not damaging the pipes ?
Can I also chase the wall to the ceiling, then cut the pipes and use flexible tap connectors to cross the pipes over? will these be ok to then be covered up behind tiles ?
