Water Leaking through beading
Raining
by Raining » Mon Jun 08, 2009 8:20 pm
When it rains water seems to be leaking through the beading of my upvc windows (at the bottom of the window (top opener) so I am guessing there is some sort of problem with the seals???...or the drainage holes??
Is it an easy job to remove the pane and change the seals..or is it a job for the professionals?
by stoneyboy » Fri Jun 12, 2009 8:31 pm
Raining,
Pull out the inner rubber seal, push the glass back from the outside and prise out the beading. you'll probably find the manufacturer has forgotten to drill drainage holes.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Fri Jul 02, 2010 8:48 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Mon Dec 23, 2024 9:29 am
