Laminate flooring tutorial
john9159
by john9159 » Tue Jun 09, 2009 12:15 pm
Are there any laminate flooring tutorials online I can read to understand the basics of fitting this product.
The size I am considering is 194mm x 1290mm.
Also does anyone have an idea of what the cost is to have someone fit this type of flooring?
Thank you
TheDoctor4
by TheDoctor4 » Tue Jun 09, 2009 5:55 pm
Have you had a look at the Laying Laminate Flooring project: https://www.diydoctor.org.uk/projects/fl ... inates.htm
This may offer you some assistance
nbbier
by nbbier » Fri Jul 03, 2009 4:20 am
Go to your local hardware store and tell someone there what you wish to do. They will probably recommend a basement floor sealing paint. Basically, it's paint mixed with a chemical compound that turns to plastic when it dries.
SWally
by SWally » Sat Oct 03, 2009 5:43 pm
Hi John. I've just bought an intruction DVD rom B&Q, only £1.50. Not bad, some of it is a bit obvious.
It is currently Mon Nov 25, 2024 6:31 pm
