Have to put slates on a low pitch roof - best waterproofing
Joe33
by Joe33 » Thu Jun 11, 2009 9:39 am
Hello,
I have to put slates on a low pitch roof (match surrounding buildings), too low to stop some water being sucked under slates , what is the best waterproofing to put over the ply decking?
Some have suggested torch on felt, how is this done, how many layers would have to be torched on?
Are they're any other options
by stoneyboy » Fri Jun 12, 2009 8:53 pm
Joe33,
A polyester reinforced roofing felt run in layer across the roof will do the job. You could use one of the modern interlocking concrete slates which are OK for a low as a 15 degrees pitch.
youasked
no hot stuff
by youasked » Thu Aug 20, 2009 9:25 am
Felting is a bit 'overkill'. Membrane will do, but I would use a rubber compound sealant on the timber, then you can forget about it. Interlocking tiles good idea from Stoney, if it has to be slate, look at new imitation ones made from weird plastic type stuff, they lock and look right too.
steveslater
Re: Have to put slates on a low pitch roof - best waterproof
by steveslater » Wed Oct 26, 2011 7:29 pm
The best way is to use the new Easy Roof System from Permavent. It is really easy to use and will allow any slate to be installed as low as 12.5 degrees. It also improves the overall performance of the roof.
It is currently Sat Nov 23, 2024 1:10 am
