Fixing tv bracket through plasterboard to blockwork
deltrasoph
by deltrasoph » Fri Jun 12, 2009 10:11 am
I have a situation where I need to fix a tv bracket to hold a small tv in a childrens bedroom.
The fixing screws would go through 12mm plasterboard, then a gap of 40mm before hitting the blockwork. In total the length of screw should be 75mm i think, but how can i get the wallplug for the screw into the drilled hole behind to take the screw???
This is my first post here although i do browse often, so would be grateful of any help.
by stoneyboy » Fri Jun 12, 2009 9:08 pm
deltrasoph,
Once you have drilled the holes in the blockwork fit a wall plug on the end of a screw and carefully push it into the holes, once located hammer the screw which will force the plug into position, then tighten the screw.
gerryyy
tapcon screws
by gerryyy » Thu Jun 18, 2009 10:44 pm
You can buy tapcon screws, just drill a hole and then screw them in, no need for plug! i use 130mm screws for such jobs. Check whioch bit you will need for these. the screws i use require a hex 30 bit, which i always loose and bloody mare when go to use them. ...good luck
It is currently Tue Nov 26, 2024 8:28 am
