Ceiling pull switch wiring
delphi2009
by delphi2009 » Fri Jun 12, 2009 6:26 pm
Can anyone help me with the wiring for this? I have 3 wires
Red - Live I think
Black - Neutral?
Green/Yellow - Earth?
The connectors on the pull switch are marked COM, 1WAY, 2WAY and there is also a seperate connector on the rose which isn't marked. Can anyone tell me which cable goes where?!!
Thank you in advance :)
kbrownie
by kbrownie » Fri Jun 12, 2009 11:29 pm
delphi2009,
Red=Com
Black=L1
Green/Yellow= earth terminal(should be marked with a symbol that has a number of horizontal parallel lines decreasing in size from top to bottom and central vertical straight line beneath these).
KB
bd3cc
by bd3cc » Sat Jun 13, 2009 1:16 am
Red to COM
Black ( which isn't neutral but a switch live and should be marked with red/brown sleeving or tape, but often wasn't) to L1/L2, it doesnt matter.
Earth green/yellow to the unmarked(dummy terminal)
HTH
delphi2009
by delphi2009 » Sun Jun 14, 2009 8:41 pm
Thank you both for the reply, it's now fitted :D
It is currently Sat Jan 18, 2025 6:18 pm
