Tiling on chipboard
stokiebill
Tiling on chipboard
by stokiebill » Fri Jun 12, 2009 8:48 pm
I am about to apply floor tiles to a new-build bathroom which is floored using P5 grade chipboard.What do I need to do to guarantee a water proof and long lasting finish?
rosebery
by rosebery » Sun Jun 14, 2009 7:59 am
1. For vinyl tiles - over board with 6mm ply and off you go.
2. For ceramics - overboard with 18mm ply and off you go OR
3. Rip it out and replace with 25mm ply.
OldandGrey
by OldandGrey » Sat Jun 20, 2009 12:13 pm
It is an important point to know that when tiling over any floor that is considered flexible i.e. timber, you should use a flexible tile adhesive and a flexible grout. These products are usually powder based to which you add water but are very worthwhile because without them you are more likely to get cracks in the grouting and possibly the tiles themselves when the floor underneath flexes and moves, expands, contracts etc. Another important point is the size of the grout joint between the tiles on a flexible floor; we almost always use 5mm tile spacers.
HTH
Grumpy Old Git
It is currently Wed Nov 27, 2024 5:15 am
