Levelling garage floor
acsimpson
by acsimpson » Sun Jun 14, 2009 2:29 am
My garage floor is uneven. I would ideally like it to have a gently run from back to front but it currently has a few holes (about 1cm deep and a run from the door inward for the 1st quarter of the length.
At the back is a work surface with washing machine under it although I can raise the surface if required it would be extra work.
In the middle is a door with step down (currently about 25cm)
At the front the garage door has a rubber seal which meets the existing concrete and would be hard to adjust for a different height.
Can someone please advise me if there is anyway I can skim the surface of the floor to provide the run off I am looking for or if I would have to redo the whole slab?
If the only option to fix the gradient is redoing the slab I will have to live with it, in which case what would be a good product to smooth the surface before painting or other coat is applied?
Thanks in advance for all your help.
OldandGrey
by OldandGrey » Sat Jun 20, 2009 12:02 pm
I'm not aware of an easy answer to get you your desired finish so the best solution might just be to use a self levelling compound to fill your patches. You can purchase different types of "latex" as we (tilers) call it and I am aware that Wickes sell a variety according to the thickness you need to apply so choose carefully.
HTH
Grumpy Old Git
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Tue Jul 27, 2010 8:58 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sat Nov 23, 2024 1:13 pm
