Small Angle Grinder
EdThomas
Small Angle Grinder
by EdThomas » Mon Jun 15, 2009 3:07 pm
I've recently purchased a small angle grinder for cutting old fittings/small bits of metal work out of walls.
The blades are wearing down, not just from the outside where you'd expect,but also from the centre. I assume i'm either rubbish at fitting the blades or i'm using the wrong blade?
Any pointers?
rosebery
by rosebery » Mon Jun 15, 2009 10:33 pm
Yes - fit the correct blade. You are obviously using blades which have a different bore from that required by the grinder.
It is currently Sat Nov 23, 2024 2:51 pm
