UPVC door accidentally glossed
momma
by momma » Tue Jun 16, 2009 11:57 pm
Hi..
After having a room decorated..I have just discovered that the upvc door (with a wood grain finish) has been painted with white gloss..
Any advice please ?
Many thanks...
chris_on_tour2002
by chris_on_tour2002 » Tue Jul 14, 2009 6:27 pm
are you sure it's a upvc door? not commonly used internally. i suspect that it's an engineered door (probably hollow) with a textured board. they can be sanded and painted.
if it IS upvc then it should not be too much of a problem to gently scrape it off once the gloss is fully dry (assuming it was a solvent based paint) which might take several weeks. in fact it will probably start peeling of it's own accord. avoid paint stripping chemicals as they will damage the pvc.
wildbill
by wildbill » Mon Sep 28, 2009 12:36 pm
wurth do a great product for cleaning off the pvc once the door has been scrapped off its called type 10 can get it from most pvc supplyers
momma
by momma » Tue Sep 29, 2009 12:17 am
Many thanks chris and wilbill..
Yes..it is a upvc door..(had them installed to save painting.. :roll: )
I will ask if it was a solvent based gloss first ..the laddie that did it didn't realise it was upvc..
Thanks for the tip re the wurth product..I'll check it out..
Thank goodness I didn't ask him to paint both sides of all 8 doors !.. :wink:
It is currently Tue Nov 26, 2024 3:50 am
