Double garage foundation query
karl hurrell
by karl hurrell » Wed Jun 17, 2009 6:54 pm
Hello,
This is my first post so be gentle with me lol.
Im building a 7 x 7m garage. I was doing a cavity wall and was advise to do the foundations 600mm wide and 800mm deep using an ST3 concrete. Im now doing a single block with piers. Can anyone suggest what width and depth foundation I should use, Im presuming it will be smaller.
Also how thick should my hardcore be for the oversite?
Thanks in advance
Karl
by stoneyboy » Fri Jun 19, 2009 9:33 pm
karl hurrell,
The depth and size of you foundations will depend on sub-soil conditions. If your garage is sited on made-up ground the foundations will need to be a lot wider and deeper when compared with those if you hit bedrock.
Hardcore depth will also depend on soil conditions - make sure the hardcore is well broken up and compacted.
bd3cc
by bd3cc » Sat Jun 20, 2009 11:46 pm
Presumably your area BC are involved: if not ask them as they will know the relevant factors in your area
It is currently Wed Jan 29, 2025 8:32 pm
