push button toilet cistern not filling up again after flush
KARENSKELLY
by KARENSKELLY » Thu Jun 18, 2009 12:45 pm
checked pages for problems but just not refilling after flush is this water presuure or something more serious - thank you - ksk
by stoneyboy » Fri Jun 19, 2009 9:35 pm
KARENSKELLY,
If the loo has worked in the past then the most likely cause is that debris has blocked the fill valve nozzle. It needs taking apart.
rosebery
by rosebery » Sat Jun 20, 2009 11:14 am
or the float is catching on something.
Colonel Moran
by Colonel Moran » Tue Jun 23, 2009 10:55 am
I have a very similar problem.
The cistern refills, but incredibly slowly.
I have opened it up, to try and see what is going on, the valve (i think) is spraying water out in a fine mist rather than filling the cistern quickly.
Can i fix this, or do i need to buy a new valve?
Really confused.
by stoneyboy » Tue Jun 23, 2009 10:36 pm
Colonel Moran,
You also need to take the valve apart and remove any debris in the nozzle.
It is currently Tue Dec 03, 2024 8:44 pm
