Can anyone suggest the best method of fixing a motorised awning blind 100kilo in weight 4 metre in length . It is an end fixed awning with 4 fixing points in each bracket . Fixing into thermalite block.
There is a great product from fischer called the 'Aircrete anchor' that uses a specially designed drill (PBB) to create an undercut hole which you fill with resin and insert a stud.
This becomes stronger than the block.
