changing emulsion
7 posts   •   Page 1 of 1
june1
changing emulsion
by june1 » Fri Jun 19, 2009 7:22 am
What do I need to change matt emulsion to eggshell?
by stoneyboy » Fri Jun 19, 2009 9:54 pm
june1,
Buy some vinyl silk in the same colour and make and mix them.
rosebery
Re: changing emulsion
by rosebery » Sat Jun 20, 2009 11:09 am
"What do I need to change matt emulsion to eggshell?"
What are you actually trying to do / achieve?
rosebery
by rosebery » Sat Jun 20, 2009 11:12 am
"Buy some vinyl silk in the same colour and make and mix them."
Eh?
bd3cc
by bd3cc » Sat Jun 20, 2009 11:13 pm
i wish people would'nt put up 2 posts on the same subject. Better to consider your post in terms that might be understood and get a sensible answer.
rosebery
by rosebery » Sun Jun 21, 2009 6:50 pm
"i wish people would'nt put up 2 posts on the same subject. Better to consider your post in terms that might be understood and get a sensible answer."
That happens here because people submit their post and because they can't see it immediately (and won't until an admin has "checked" it for safety - perhaps some considerable time later) they think they did it wrong and post it again. Its a function of the way this forum works.
However, in this case the question is also poorly phrased although I guess the OP clearly understands what they were trying to say.
Interpretation attempted on the other thread.
theshedman
by theshedman » Fri Jul 10, 2009 9:56 am
Hi, If you want eggshell type finish just use a Vinyl Silk emulsion. If you mix it with a Matt finish it will probably end up being patchy. To get a proper eggshell finish you will need to buy eggshell paint. You won't actually make an eggshell finish using a matt emulsion.
It is currently Wed Nov 27, 2024 12:28 pm
