Converting the loft
Rastanking
Converting the loft
by Rastanking » Sun Jun 21, 2009 3:41 pm
Hi everyone,
I am thinking of converting the loft just for space, however are there special boards that I need, ie fire resistant and what are the implications of putting the boards over the insulation which currently has the lighting circuit running through it.
Would this be a fire hazard?
Thanks in advance
by stoneyboy » Sun Jun 21, 2009 9:35 pm
Rastanking,
Plasterboard on the ceiling below the loft will provide the fire resistance. Use T&G chipboard for the floor. You should not be encasing the wiring in loft insulation - if its ontop or underneath the insulation you should be OK provided you have not got any outside halogen floodlights fed by the lighting circuit. Take care not to pinch any cables running on top of the rafters.
Rastanking
by Rastanking » Tue Jun 23, 2009 12:57 pm
Cheers for the help Stoneyboy
It is currently Sun Sep 29, 2024 1:16 am
