Fitting window in doorway
Locksmith
by Locksmith » Tue Jun 23, 2009 11:26 am
I intend blocking up the doorway in the kitchen and fitting a window in the top part of the opening. Unfortunately I have to reduce the reveal by about 50mm each side.
What are the issues regarding the damp coarse, I know I have to have 375mm below the cill, but what about the sides. There is going to be limited room for DPC if I need it.
by stoneyboy » Tue Jun 23, 2009 10:51 pm
Locksmith,
The main problem will be adding 50mm to each side of the existing opening - you will probably have to remove the existing cavity closure and reform it to make the smaller opening.
It is currently Tue Jan 07, 2025 3:49 am
