Membrane above celotex insulation?
andypitts
by andypitts » Fri Jun 26, 2009 11:10 am
Am planning to insulate between the sloping roof rafters in the attic of a large 1860's stone built semi.
As it happens, the next door semi is having their roof slates replaced at the moment. Like mine, these are the original thick old Welsh slates - and there is no felt beneath them at all ie they rest directly on the wood sarking boards with the attic space underneath this. So the builders are laying down a breathable waterproof membrane on the sarking first to then lay the new slates on top of.
I can't afford a new slate roof myself but am worried that old cracked slates plus no underlying felt = leaks into the attic space.
Should I pin some membrane pieces up to the underside of the sarking boards first before fitting the Celotex insulation panels in place?
Maybe I can use the same membrane next doors builders are using - says M7550-1B on it?
by stoneyboy » Fri Jun 26, 2009 9:09 pm
andypitts,
Replace the broken slates and fix the insulation under the rafters so that there is a ventilated gap between the boarding and the insulation.
bd3cc
by bd3cc » Fri Jun 26, 2009 11:31 pm
Think you could be wasting your time. Sorry!
andypitts
by andypitts » Sun Jun 28, 2009 10:18 am
thanks but not not sure in what respect I might be wasting my time?
cheers
Perry525
by Perry525 » Mon Jul 06, 2009 7:03 pm
Its hard to understand where you are going with this?
Lets start by saying that "old Welsh slates" may be old but, they are good for four hundred years (if they are Welsh slates.)
So, why would anyone wish to disturb them?
Have the nails gone?
Do the slates rattle in the wind?
One type of repair is to slide a piece of aluminium under the slate, cut to size it will be invisible.
I have seen roofs where they have been glued together.
Your slates seem to have worked well for over a hundred years, without a membrane...........
It is currently Sun Dec 22, 2024 1:42 pm
