removing adhesive
bermudaby
removing adhesive
by bermudaby » Sun May 27, 2007 10:58 pm
I have just removed some 1970/80's heavy wallpaper which was hung on wood using a very heavy glue like adhesive. The adhesive is lumpy and black and very tough. Is there a product that will remove this 'paste'. I'll be grateful for any info.
thedoctor3
by thedoctor3 » Mon May 28, 2007 12:52 am
Hi, I had a similar problem a while ago with hard heavy adhesive. After unsuccesfully trying solvents, I ended up using a Heat gun & scraper. Came off easy . See our Toolstore for a hot air gun.
78602 Titan HG2000XP 2000W Heat Gun 230V
bermudaby
by bermudaby » Mon May 28, 2007 8:14 am
Many thanks for the prompt repy. I'm not sure if a hot air gun would be suitable as the paper was on plywood and not a normal wall! I'll give it a try though.
It is currently Fri Nov 22, 2024 9:29 pm
