IS THERE A WAY TO LUBRICATE MY SUBMESIBLE WELL PUMP?
stra8up3
by stra8up3 » Sun Jun 28, 2009 4:28 am
I have gotten the well pump and motor out of the ground and had to buy a new moter. The pump seems dry. Is there any way to lubricate it??
rosebery
by rosebery » Sun Jun 28, 2009 3:18 pm
Yes there must be of course. Check your manufacturers instructions or if you don't have same then google for them.
plumbbob
by plumbbob » Sun Jun 28, 2009 4:05 pm
I can't speak for your particular pump, but usually submersible pumps use the surrounding water for lubrication and nothing else is required. In fact, the instructions often stress that other lubricants should not be used.
by htg engineer » Mon Jun 29, 2009 8:33 pm
As Plumbbob says - water is normally used for lubrication - nothing else needed.
Check with manufacturers if possible.
htg
It is currently Mon Nov 25, 2024 9:31 pm
