Low Pressure Newlec Calypso
timv128
by timv128 » Wed Jul 01, 2009 9:22 pm
Hello there, It's my first time of posting , so please be gentle. I have a Newlec calypso plus shower which has severley reduced pressure, Even on the cold setting and turn the handset upside down, it goes about two inches out of the thing, the main problem is that if you turn the water up hotter, the flow gets so slow, right up to the point where if you turn it up to anything over two thirds heat, no water at all comes out....any help would be HUGELY accepted......
by htg engineer » Thu Jul 02, 2009 3:39 pm
Check and clean filters, if it's old then it may be all furred up inside (limescale) reducing the flow.
htg
timv128
by timv128 » Thu Jul 02, 2009 9:21 pm
is there any way of cleaning it ? or cleaning the filters, or does it just mean replacing the shower ?
by htg engineer » Sat Jul 04, 2009 5:09 pm
You can clean the filter, check in the cold water connection.
If the unit is furred up - best of renewing the shower.
htg
It is currently Sat Dec 28, 2024 8:28 pm
