NO HOT WATER!
6 posts   •   Page 1 of 1
daztc
NO HOT WATER!
by daztc » Fri Jul 03, 2009 9:15 am
we are unable to get water from the hot water taps.barely a trickle.all rooms affected..cold taps ok...have checked header tank, that is filling ok,.
by htg engineer » Fri Jul 03, 2009 3:14 pm
Could be airlocked, if you have a mixer tap - place you thumb over the end and open the hot and cold tap - the cold water will backfill the hot water pipes.
If you don't have a mixer - use a short cutting of hose to connect the two taps.
htg
daztc
no hot water
by daztc » Sat Jul 04, 2009 5:12 am
apparently their is also no cold water, nor is the toilet cistern filling..all this is in the bathroom, i assume all are fed from same supply and had hoped to find somewhere in supply shut-off valve or at least a compression joint i could have loosened, but without luck...is their anyother way to force air out ?....
daztc
no hot water
by daztc » Sat Jul 04, 2009 8:18 am
unfortunately it is also the cold water..all this in the bathroom..hoped to find a stop-cock or compression fitment to release any air but no luck..is their any other way to clean the airlock
rosebery
by rosebery » Sat Jul 04, 2009 11:47 am
Have you checked if the outlet from the CWST is blocked?
by htg engineer » Sat Jul 04, 2009 5:04 pm
Check the ball valve in the tank - it can't be full, it's very unlikely to have an airlock in the hot water pipework and the cold water pipework - if no valves have been tuned off - the cold water taps in the bathroom and the cylinder must be fed from the same cold water tank in the loft.
htg
It is currently Wed Jan 15, 2025 10:51 am
