Removing stuck on shower hose
piperd
by piperd » Fri Jul 03, 2009 8:28 pm
I'm trying to replace my shower hose with a new one. The problem I am having is that I cannot seem to able to turn the threaded connector at the elbow end of the hose. There is no problem unscrewing at the showerhead end, I have tried both locking and waterpump pliers for removal. Has any anyone got any ideas on how to remove it?
rosebery
by rosebery » Sat Jul 04, 2009 10:52 am
Apply a bit of heat. If its a metal connector then differential expansion should loosen it. If its a plastic one it doesn't matter as you are replacing it anyway LoL. If its plastic you could also cut through it lengthways if you can get the correct angle.
It is currently Wed Dec 04, 2024 7:30 pm
