window headers.
garryacovington
window headers.
by garryacovington » Fri Jul 03, 2009 11:57 pm
Good evening all,
I have two window headers on the upper level that are cracking/crumbling and the cement is falling off in lumps. Apart from looking messy they are a danger to visitors knocking at the door!
My question is: How should I go about repairing or replacing them ?
regards, Garry.
chris_on_tour2002
by chris_on_tour2002 » Tue Jul 07, 2009 10:19 am
difficult to advise without actually seeing it but perhaps the best option would simply be to remove all unsound material, apply angle bead and re-render.
is it only the render that's breaking up and coming loose? if it's the lintel then it's a much bigger issue.
while you're at it i'd be inclined to chip off a fair bit of the render above the windows by a course or two and have a look at what's going on beneath. may be some movement causing the render to come away.
teamleader1
by teamleader1 » Thu Jul 16, 2009 8:00 pm
Tapping the render around the problem area with your knuckles is a good way of identifying whether the render is spoiled and lifted, a hollow sound will confirm this
All affected areas will have to be removed and repaired.
As Chris said, if it turns out to be a problem with the lintel its a bigger issue.
It is currently Sun Nov 24, 2024 6:30 am
