Since moving into a 20 year old house last september, we found both showers to be faulty. The main issue being that the mixer shower temperature could not be altered. I have recently installed a new high pressure mixer shower in the ensuite as the system is using a combi boiler. The new shower has not made any difference and i have since discovered that I have a cold water tank in the loft. At first i thought this tank was redundant but have now found that the cold water supply to the shower is fed from this tank by gravity. Am I right in thinking that if the hot and cold pressures to the shower are NOT equal, then the shower will not work??? Shouldn't the shower be fed from the cold water main feed?
Any help would be appreciated.
