Can I cut a soil pipe off in the loft space and insert a one way air valve?
WHYDIY
by WHYDIY » Sat Jul 04, 2009 8:53 pm
I have a plastic soil pipe that goes up through the house and out of the roof and has a open normal vent on top.
Can I cut the pipe off in the loft space and insert a one way air valve?
(making it possiable to remove the roof vent with leaky flashing)
Many Thanks M
rosebery
by rosebery » Sun Jul 05, 2009 3:49 pm
In principal yes you can except that you MUST have at least one vent open to atmosphere. If this is the only soil/vent stack you have then the answer is no.
Have you considered though that if you did it then have a hole in the roof that has to be repaired the cost of which will probably be not much different to getting the flashing fixed. Just a thought.
It is currently Fri Nov 22, 2024 11:26 pm
