Crack in Grout Around Window Sill
raymitchell
by raymitchell » Mon Jul 06, 2009 1:53 pm
Several weeks ago a crack two inches long formed in the grout on part of my windowsill. I removed the existing grout and applied new grout but it keeps on forming a crack in the same place. As the grout is near the edge and fixed to the PVC window frame I think that the PVC frame is moving when the weather is hot and the crack is forming. Does anyone know how to stop this happening?
Kind regards
Ray
plumbbob
by plumbbob » Tue Jul 07, 2009 12:24 am
You can't use grout for gaps that will either move or expand at different rates. uPVC does both - flexes and expands more than tiles. The gap should be filled with a bead of white silicone.
raymitchell
by raymitchell » Wed Jul 08, 2009 12:12 pm
We have a large grouted border around the kitchen window sill tiles of about 2 cms. The rest of the window sill is fine apart from a two inch section. :(
rosebery
by rosebery » Wed Jul 08, 2009 9:23 pm
Bob is right. I thinkyou should do as he suggests or sooner or later it will become biger than a 2" problem.
www.tileexperience.co.uk
by www.tileexperience.co.uk » Sat Aug 22, 2009 5:32 pm
hi new to this site, but not to tiles.
i think you are lucky a crack hasn't appeard before now. i agree with the others and suggest a bead of silicone.
there are flexible grouts you could use if you really want, but you may have to add additional flexible additive and there still wouldn't be a guarantee.
It is currently Sat Nov 23, 2024 7:28 am
