by plumbbob »
Tue Jul 07, 2009 12:20 am
Just a couple of points I would add, if you fix a pipe from your flat, then you are fixing a pipe to someone else's wall. There may be restrictions with regard to this. On another point, if the tap is to be fitted in a communal area, give consideration to protecting the tap as these often become a target for theft or vandalism let alone use by any Tom Dick or Harry.
