Laminate flooring in bathroom with existing toilet/sink
Loki7430
by Loki7430 » Mon Jul 06, 2009 3:33 pm
Wonder if you can help. I hoping to remove an existing carpet from our bathroom and fit laminate flooring instead. There is a hardboard floor with a sink and toilet screwed into it, and the carpet is laid around these.
Now, I had thought I'd need to lift the toilet and sink and lay the laminate underneath? But I am worried that by the time I lift it over the new laminate and underlay it will be a good centimetre or so higher than where it is now and the exisiting plumbing and waste pipes will now longer line up.
Am I better to leave them where they are, cut the laminate to fit and hide the gap with sealant, or is this too much of a bodge job!! I have done a bit of DIY but only a bit!!
rosebery
by rosebery » Tue Jul 07, 2009 11:06 pm
Unless you want to adjust the plumbing you probably have no alternative than to cut round the existing sanitary ware. Make a paper template of thebase of the units and transfer that to the laminate. Use a down cutting blade in your jigsaw and you won't splinter the surface of the laminate. Oh and yes a bead of silicone around the base when you've finished.
Loki7430
by Loki7430 » Thu Jul 09, 2009 12:08 am
Thanks for the tips... just remembered the top of the sink is also grouted and sealed in - another can of worms. Flooring around the exisitng units it is.
Thanks again....
It is currently Wed Dec 25, 2024 5:00 am
