Stair Trimmer Joist
g8kps
Stair Trimmer Joist
by g8kps » Tue Jul 07, 2009 12:07 am
The design of my first floor extension called for 3 150x50mm joist bolted together for the trimmer joist. However when the joist timber was delivered it was a nominal 47x150mm, when measured it was just 45x150mm. My problem is that all the wood-to-wood joist hangers that I have found are ether too big 150wide or too small 125wide. I have tried to find another timber suppler of 50x150mm c16 without luck.
Can anyone suggest a solution?
Ray
by stoneyboy » Mon Jul 13, 2009 10:42 pm
g8kps,
Don't understand your reference to "too big 150wide" or "too small 125 wide" but if you must have 50x150 find a timber merchant with a saw mill and get them to cut 75x150 to the size you want.
It is currently Fri Nov 22, 2024 3:17 am
