Problem with installing a new light
el_stig
by el_stig » Tue Jul 07, 2009 1:16 pm
I have read through a few people's problems, and also read a couple of guides, but alas, to no avail.
I am replacing a light, i did not remove the old unit, therefore dont know where the wires came from. It is part of the downstairs ring and has 5 wires going into the it, 3 of these have live, neutral and earth, 2 have just live and earth. The light also has 2 switches which operate it.
I have wired up the ring a number of times and all the lights work, but the kitchen light (the one i am changing) is always on! I have found (i think) that one of the black wires is the switch light, i have marked this, but it still doesnt change anything.
can anyone think of a way to wire this up i may not have tried? i can take photos if that would help anyone!
if i havent explained clearly please ask me to clarify!
thanks for any help in advance!
BLAKEY1963
Re: Problem with installing a new light
by BLAKEY1963 » Wed Jul 08, 2009 10:37 am
[quote="el_stig"]I have read through a few people's problems, and also read a couple of guides, but alas, to no avail.
thanks for any help in advance![/quote]
el-stig
the black with a red tag ( your switch) wire goes ito the light fitting , live
terminal . this should switch your light. Isolate supply safely.
you could also get the advice of your local electrician to verify.
BLAKEY1963
by sparx » Wed Jul 08, 2009 6:16 pm
I would guess what you have is an old fashioned way of 2 way switching, using single core plus earths .
to confirm look at connections to Com. terms at switches, if the above cables go there then I am right.
Please look at switches & tell us what cables and colours are there,
as Blakey says this may need 'hands on' help as combinations are many,
sorry,
Sparx
el_stig
by el_stig » Wed Jul 08, 2009 11:00 pm
Inthe two plugs are single core plus earths, so i immediatly assumed that connecting these to the fitting would give the switching i needed, but using a continuity tester i found a switch live (but since connecting this i have found that i have connected the switch from the lounge!)
i think sparx u are right! this maybe too much for me to explain over the internet and being a total novice, i may have to accept defeat!
thanks for your help!
It is currently Sat Jan 18, 2025 10:11 am
