Partion wall
Gilmore
Partion wall
by Gilmore » Tue Jul 07, 2009 3:07 pm
Hi all
I planning to build a partition wall and make one bedroom into two.
The room being divided has laminate floor,should I just build the partition wall on top of this or cut out a section so that the wall rests directly onto the floorboards
tav
by tav » Wed Jul 08, 2009 10:10 pm
I personally would cut the laminate and fix the stud wall directly to the floor as if you decide to lift the laminate at a later date, it may cause problems if its under the wall. Also laminate should not be restricted in any way so it can still move.
rosebery
by rosebery » Wed Jul 08, 2009 10:18 pm
- Take up all the laminate floor.
- Build your partition wall.
- Do eveything else you need to do.
- Relay the laminate flooring in both rooms.
It is currently Sat Nov 23, 2024 12:46 pm
