draining central heating system
homeedmum
by homeedmum » Mon May 28, 2007 1:07 pm
Is it just a 'normal' piece of garden hosepipe that you need to drain the system or does it have to be a specific size.
by htg engineer » Mon May 28, 2007 9:16 pm
normal hosepipe connested to a drain valve is ok, you may find it leaks abit so a jubilee clip can be used. Alternatively insert some 15mm copper pipe into the hose pipe and connect with a nut and ring to a radiator valve.
It is currently Mon Dec 23, 2024 3:30 am
