Fixing Garden Sail Shade to uPVC Conservatory Window Frame
ptarmigan
by ptarmigan » Mon Jul 20, 2009 3:59 pm
I want to put up a triangular garden sail shade with one of the corners permanently attached to the uPVC frame of my conservatory. As the shade is tensioned with a turnbuckle, the fixing needs to be very robust and weatherproof. Should I use a pad eye screwed to timber which is stuck to the uPVC frame with adhesive (solvent-free 'gripfill'?), or is there a better method like special uPVC screws?
rosebery
by rosebery » Mon Jul 20, 2009 10:02 pm
Bearing in mind the stresses you will put the fixing under methinks you need to screw it in.
ptarmigan
by ptarmigan » Tue Jul 21, 2009 9:33 am
Thanks, I was coming to the same conclusion - seems a shame to drill right through the frame, but an eye bolt is probably the most secure.
by htg engineer » Tue Jul 28, 2009 9:24 pm
I don't know the age of your conservatory, and this isn't really relevant to your post - but drilling the conservatory will void and guarantee/warranty.
htg
It is currently Mon Dec 23, 2024 1:34 am
