Consumer Unit
neilybhoy
Consumer Unit
by neilybhoy » Thu Jul 23, 2009 2:42 pm
I am installing a new consumer unit for a loft conversion which will be connected to the existing CU down stairs. I am changing the main switch on the new CU for a 63A RCD. The RCD I have bought has 4 terminals - on the top it has 1 and N and on the bottom it has 2 and N. Am I correct to say that I connect the new live and neutral to the 1 and N on the top and connect the N on the bottom to the neutral bar in the CU? The 2 on the bottom will be used for the bus bar connections to the MCBs?
moggy1968
by moggy1968 » Thu Jul 23, 2009 7:11 pm
are you aware that this work is notifiable under part P legislation?
It is currently Sat Jan 18, 2025 11:07 am
