kitchen tiles
sanjan
kitchen tiles
by sanjan » Sat Jul 25, 2009 2:47 pm
My kitchen is currently tiled all over with pale blue tiles is it possible to tile on top of these .as the work to remove would be endless plus it may take some of the plaster off which would then need plastering there normal ceramic tiles if so would i need a stronger adesive thanks in advance .
plumbbob
by plumbbob » Sun Jul 26, 2009 4:33 pm
If the original tiles are firmly fixed then yes it is possible to tile over tiles however doing so creates it's own problems.
Doubling the thickness of tiling will often see architraves around doors being shallower leaving the edges of the tiles exposed. If areas are half tiled, then trims don't fit. You may also have trouble around electrical fittings and cupboard doors next to walls may catch the new tiles and appliances may be forced proud of the worktops.
www.tileexperience.co.uk
by www.tileexperience.co.uk » Sat Aug 22, 2009 5:34 pm
much better to pop the other tiles off and do a perfect job, you'll appreciate it in the end when you realise edges, meetings against skirts and architraves etc all look as they should do.
TheDoctor4
help at hand
by TheDoctor4 » Tue Jul 20, 2010 6:57 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
CounterTop
by CounterTop » Tue Aug 17, 2010 8:52 am
Just remove the tiles first and then fixed all the tiles as you want then till will look beautiful...without any extra plastering.
It is currently Sat Nov 23, 2024 7:43 am
