ELECTRIC SHOWER
BARKER689
ELECTRIC SHOWER
by BARKER689 » Fri Mar 02, 2007 5:54 pm
I HAVE JUST FITTED MY 9.5KW ELECTRIC SHOWER AND WHEN I TURN ON THE POWER THE NEON LIGHT ON THE UNIT IS DIM AND FLICKERS THEN WHEN I TURN ON THE STOP/START BUTTON ON THERE IS NOTHING AND THE POWER LIGHT GOES OUT THEN I PRESS THE STOP/START BUTTON OFF AND THE POWER LIGHT COMES BACK ON AND AGAIN IS DIM AND FLICKERS I DO HAVE 240V AND A 40A FUSE MY PREVIOUS SHOWER WAS EXACTLY THE THE SAME WHICH I HAD FOR ABOUT 2 YEARS AND HAS JUST STOPPED WORKING IN THE SAME WAY ANY IDEAS THANKS
stanley
by stanley » Wed Mar 07, 2007 9:53 pm
you could check what ampage your incoming is, is it a 60 amps and are you overloading the system? what cable size have you to the shower.
thedoctor
by thedoctor » Fri Mar 16, 2007 2:34 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sat Nov 23, 2024 1:53 pm
