Cooker Circuit Protection
alina123
by alina123 » Thu Jul 30, 2009 10:21 am
Hi there,
Help needed!!!
Can anyone confirm that the new regulations state that any new cooker circuit/installation must be fitted with an RCD unit? :?
I'm just about to fit new circuit for my cooker and i want to make sure its up to the new standard???
In the project section it states wire direct from consumer unit to the CCU???
moggy1968
by moggy1968 » Thu Jul 30, 2009 7:05 pm
yes it does, and this is also notifiable under part p so needs to be done by someone registered on the appropriate scheme, or notified to building control BEFORE work starts
by sparx » Thu Jul 30, 2009 7:13 pm
Hi, several points here,
1) any new circuit is subject to 'Part-P' registration with LABC.
2)any wiring in a kitchen is " " " "" " " " .
3)all wiring not surface run or protected by earthed metal covering must be protected at source by an RCD.
4)a cooker must be run on an independant circuit from consumer unit.
5)All installation work must have electrical certificate issued showing test results
so only real option is to call in registered electrician who can do all the above since cost of notifying Local Building Control will rival cost of having job done professionally with certs. issued,
regards SPARX
N.B. if it was a gas cooker would you try to do that installation from meter yourself?
alina123
by alina123 » Sun Aug 16, 2009 9:34 am
Thanks for the help :shock:
It is currently Sat Jan 18, 2025 7:47 am
