Water Cylinder
tt
Water Cylinder
by tt » Wed Aug 05, 2009 8:46 am
We have a hot water cyinder with 2 parts hot and smaller cold tank at the top could you diagnose what maybe causing the cold to heat up.
thank you
dipatt
HOT WATER CYLINDER - Which way to turn red valve?
by dipatt » Sat Aug 29, 2009 6:44 pm
Hi, I have just moved into an old house and am on a low income. When I put the oil-fired central heating on the water is luke warm after eg 2 hours. If I use the immersion heater the water gets cold quickly (there is insulation attached to the hot water tank/cylinder).
I have a red valve tap at the top of the hotpress cylinder and tried turning it and wonder if I have made it worse.
Could some kind person please tell me should it be turned fully clockwise or anti-clockwise to ensure the water is heated and will possibly remain warm enough the following day?
Thank you
Di
It is currently Mon Nov 25, 2024 7:50 am
