Can Efflorescence occur on mortor joints also?
bbillcee
by bbillcee » Tue May 29, 2007 12:03 am
i had new patio built around certain bricks the mortor is very white compared to rest of brick
also the bricks where it is were old brick used from the old porch....could it be some reaction to mortar?
thedoctor
by thedoctor » Thu May 31, 2007 8:15 am
Possibly or it could be a different mix of sand and cement used in these areas. Efflorescence can certainly be found in brickwork joints but this forms a powder on the surface of the joint as well as (usually) being white in colour.
bbillcee
by bbillcee » Thu May 31, 2007 8:21 pm
this is what i mean!! please tell me i can do something about this!
[URL=http://imajr.com/000_0109_87730][IMG]http://imajr.com/th/000_0109_87730.jpg[/IMG][/URL]
glen-paul wilson
white staiing on brickwork
by glen-paul wilson » Sun Oct 07, 2007 2:54 pm
it is a common missconception that this problem can be removed by brick acid but the truth is that all brick acid will do is attack the sand in the mortar what you need to attack is the lime to do this you need to use phospheric acid and not hydrochloric acid which is commoonly known as brick acid & alloy wheel cleaner trust me i was in the concreet industry for thirteen years and now own a cleaning copany that specializes in brick cleaning among other things google trucking clean manchester
It is currently Sun Jan 05, 2025 5:21 am
