by moggy1968 »
Sat Aug 08, 2009 10:10 pm
that sounds ok, as long as the repair is accessable for maintainance as I think you are talking about the screw type choccie blocks. I would wrap them in 3 layers of insulating tape as well, I have had a fizz off blocks before, even though they are supposed to be insulated, and a loose cable could theoretically find its was into the wrong opening if soemthing came adfrift. What you can't do, which you avoided the temptation of doing, is choccie block it, then plaster over the top, so 10/10 for that!!
